08-11-2023, 01:03 AM
No matter which device you have among the above we have mentioned, you can easily download FuboTV on your device using this guide. So, for more info, let's get started with the guide further and see how to activate FuboTV using fubo.tv/connect sign in, fubo.tv/xbox-connect code, etc.
On Firestick:
[*]With your FireTV remote, click the home button to access the Home screen.
[*]Go to the Search icon and look for FuboTV.
[*]On the search results page, click the FuboTV app.
[*]Then click the install button.
[*]To launch the application, click Open.
[*]Fubo TV is now ready to be activated on your Firestick.
On Xbox One:
[*]Go to the Store section of your Xbox console and select Apps.
[*]Enter fuboTV in the Search for Apps field.
[*]Download and install the Fubo TV app.
[*]To activate FuboTV, open the app.
On Roku:
[*]You will need a WiFi or internet connection to use your Roku device.
[*]Go to the Roku Home Screen and click Streaming Channels.
[*]You can now access the Roku Channel Store.
[*]Search for Fubo TV in Search Channels.
[*]On the results page, click fuboTV.
[*]Select Add Channel.
[*]Now you're ready to activate Fubo TV on your Roku.
On Android TV:
[*]On your Android TV, navigate to the Play Store.
[*]Then click the Search button.
[*]You can find the FuboTV app by searching for it.
[*]From the search results, select FuboTV.
[*]Select Install from the menu.
[*]After that, launch the FuboTV app and generate the activation code.
On Apple TV:
[*]Open your Apple TV's App Store.
[*]Find FuboTV by searching.
[*]Click Get on the fuboTV app.
[*]To launch the FuboTV app, click Open.
[*]It is important to write down the activation code.
On LG Smart TV:
[*]Go to the LG Content Store.
[*]To search, click the Search button.
[*]In the search bar, type fuboTV.
[*]Install fuboTV from the search results.
[*]For the activation code, open the FuboTV app.
On Vizio Smart TV:
[*]On your VIZIO Smart TV, go to the Home Screen.
[*]Go to the App Store.
[*]Use the search bar to find fuboTV.
[*]To install the app, click Add to Home.
[*]You will need to launch the FuboTV app to get the activation code.
Step to cancel Fubo TV subscription:
So, here are some easy steps that will surely help you cancel your Fubotv/connect subscription:
[*]To create a profile, sign in to your Fubo TV account.
[*]Next, tap the My Account option next to the current profile.
[*]Then choose "Subscription and Billing" in My Account.
[*]Select "Cancel Subscription" on the next screen.
[*]To pause or cancel your subscription, select Complete Cancellation.
[*]If you want to break from Fubo TV, consider pausing your subscription.
[*]Whenever you are prompted to redeem an offer, select "REDEEM OFFER." Otherwise, select CANCEL SUBSCRIPTION to cancel your subscription.
[*]When you successfully cancel your subscription, a confirmation message will appear on your screen.
On Firestick:
On Xbox One:
On Roku:
On Android TV:
On Apple TV:
On LG Smart TV:
On Vizio Smart TV:
