« قبلی 1 … 18 19 20 21 22 … 36 بعدی »
How to remove Gems in Diablo 2: Resurrected
bertramuzi آفلاین
ارسال‌ها: 5
موضوع‌ها: 5
تاریخ عضویت: Mar 2022
06-06-2022, 02:34 PM
Single runes can be found anywhere they want in Diablo 2: Resurrected, starting in Normal difficulty through the Hell difficulty D2R Items. Runes can be plugged into sockets, as gems are, so they can be put into the socket of your gear to gain their effects.
However, the true magic of runes comes when you combine them in a particular order within an item. Runewords, also known as, are some of the most useful items you can find in the game, and are right between special items and set items. The complete list of runewords is available in the next section.
The use of runes is also possible in specific Horadric Cube recipes. In particular, you could mix runes with Ral rune and a damaged piece gear to repair it. This is a great option for those who are low on gold and don't have the money to make repairs from a vendor. Runes are also able to be combined in the Horadric Cube.
This is often referred to as "cubing in" and is a popular method to gain access to the next rune without having to find that rune in the wild. For instance, if have three El runes but need the Eld Rune you can place three El runes into the Cube and press the transmute switch. In will pop out one Eld rune. This upgrade recipe is contained in the rune table below.
The quest for Hellforge within Act 4 will always drop the runes. In fact, it is frequently used to pay to get a speedy passage through the scene. The Countess's room, in the bottom of the Forgotten Tower in Act 1's Black Marsh, is another great source for runes.Because the runes are categorized by limit of rarity buy diablo 2 resurrected items, which ranges from most frequent (El) all the way to the most rare (Zod), they're often employed as an economy in Diablo 2.
زمان کنونی: 25-03-2026، 11:30 AM Persian Translation by MyBBIran.com - Ver: 6.5
