« قبلی 1 … 30 31 32 33 34 … 53 بعدی »
Who do not update features that are shooting will fight to shoot
Amerzone آفلاین
ارسال‌ها: 4
موضوع‌ها: 4
25-03-2021, 01:51 PM
You are aware of what the remedy for this is? Go back to pre gen times that are current and remove this Nonsense Green 100% make mechanic. In the event you Hit Green, then you get the highest shot percentage in accordance with the shot quality as well as your score with Buy NBA 2K21 MT. why? You are able to eliminate ratings from NBA 2K21. Thats dumb. It should issue more that you can get the right players in the right Situations to their skillset than in case you may press a Button for the correct quantity of time. So just say goodbye to the skill difference then? Obtaining good at pressing on a button will be the point. Garentee NBA 2K21 gets worse if you take out greens.
Why do you believe this"pressing a button" is the sole skill difference in this game?! The ability gap is to have, like I already said, the ideal players (with all the ideal ratings!) In the positions to score. It is a skill to see that Rudy Gobert, although being wide open, is not a threat to score from the outdoors and also to make the decision in a millisecond to not to pass to him but to somebody rather, who's able to do anything with the chunk. That's what basketball is about: Decision making in a short timeframe. Creating mismatches. Making use of errors of the defense.
Yes, pressing on a button aka shot timing ought to factor in, but only to some margin that is small and not as prominent as it is right now. Why even have stats then? Should a three green it goes in, if not it dominates. Should you green a sneak then or even then you steal the ball it's a foul. If you green a dunk, it moves in, and should not then it bricks. Does that look interesting? I am speaking about shots. If you want to have all skill out of scoring then whatever but that's not a fun game. It still would take ability to score. You would have to create better shots instead of spamming 100 dribbles and greening a shot.
Imagine if somebody with 50 driving dip could posterize 3 defenders by simply"greening" a dunk. That will take skill, but it does make sense? Not the same. I believe that when a participant gets skilled enough to shoot a build with 50 3pt then greens shouldn't be taken away by you. I believe NBA 2K21 should reward skill.How is distinct from the very first remark I made? If someone is proficient enough to green steals with a 50 steal rating then they need to be able to steals. If someone is proficient enough to green dunks using a 50 driving dunk they should have the ability to green dunks.Ever since the leak around NBA 2K21 having a MyCareer storyline, I've seen a lot of posts and videos about NBA2king. Some say that if they are allowed in precisely the same area as men they will refuse to play with with/against them or we have to just have another neighborhood from them. Why? Is your masculinity currently likely to be stripped from you by obtaining your virtual player crossed up by a digital lady at a baseball game that is virtual or dunked on?
زمان کنونی: 06-02-2026، 09:22 AM Persian Translation by MyBBIran.com - Ver: 6.5
