« قبلی 1 … 68 69 70 71 72 … 138 بعدی »
What do you like doing more?
Smarthuiyuan آفلاین
ارسال‌ها: 3
موضوع‌ها: 3
16-03-2021, 11:31 AM
The worlds are much more visually rich, more dramatically scaled. Just as my veteran soul may be stirred by wow classic gold the sight of this canyons of Thousand Needles or the Borean Tundra, there is not anything from the old game that can touch your first sight of the excellent, burnished ziggurats of Battle for Azeroth's Zuldazar. The story is so much more confident, pulled from the pursuit text and into the action, though your progress through the game is provided a strong thematic spine: base-building, a warfare effort, a quest for a great artifact weapon. The planet is less secretive but more bountiful, dotted with treasure and boss creatures to draw you off the beaten path. An invisible slot machine sometimes upgrades your quest-reward items using a flourish, simply because you deserve it. It's such a luxurious experience. In the event you need to trudge through 10-year-old articles for this? Of course you should not.
Obviously, there are a number of oddities. Whilst the level scaling handles most situations perfectly well, it is occasionally apparent that you are playing what was originally high-level material when not yet out of your teens: Legion's class-specific quests, for instance, sometimes set up enemy patterns designed for skills you do not have yet. Chromie Time, meanwhile, isn't clearly signposted and a little confusing at present. You can, it seems, scatter around between expansions at will using the present geographic links, instead of asking Chromie to time-shift you to if you want to go, but it throws up some inconsistencies and scrambles a few quest-lines (at one point, I entered Orgrimmar's great hall to find both Sylvanas and Garrosh were Warchief, simultaneously).
This overhaul really does is alter World of Warcraft from a game that's organised geographically, as a monumental odyssey through its numerous storied landmasses, to one which is organised chronologically. WOW is no more set over its entire history. It's set over the previous two years. It is possible to choose out of that if you need, but the sport as great as things out for you that you are bending the rules to buy classic wow gold do so and carrying an unwarranted excursion into the past. Why return?
زمان کنونی: 16-04-2026، 12:24 PM Persian Translation by MyBBIran.com - Ver: 6.5
