تالار گفتگوی کیش تک/ kishtech forum › پردیس فناوری کیش › زبان های خارجی v
« قبلی 1 … 7 8 9 10 11 … 23 بعدی »
Which courses should be selected after 12th?
pihugupta آفلاین
ارسال‌ها: 6
موضوع‌ها: 6
تاریخ عضویت: Dec 2020
13-01-2021, 11:47 AM
This is one of the most confusing periods to select the courses after 12th. First you should counsel yourself. Suppose that;
You have chosen PCM stream or PCB stream or Commerce or Arts in 12th standard. It means you have chosen your area of interest. Do not surprise or tense. You have done your best. But yes, off course, if you wish to change your field for higher studies, you can go through many options according to your interest. /
زمان کنونی: 28-03-2026، 05:13 PM Persian Translation by MyBBIran.com - Ver: 6.5
