تالار گفتگوی کیش تک/ kishtech forum › پردیس فناوری کیش › زبان های خارجی › زبان انگلیسی v
« قبلی 1 … 5 6 7 8 9 … 22 بعدی »
Greeting
Greeting
Marjanbesarati آفلاین
ارسال‌ها: 22
موضوع‌ها: 22
تاریخ عضویت: Sep 2020
12-09-2020, 11:41 PM (آخرین ویرایش: 17-09-2020, 12:08 AM، توسط Marjanbesarati.)
پردیس فناوری کیش_طرح مشاوره متخصصین صنعت ومدیریت_دپارتمان زبانهای خارجی:http://kishindustry.com
Story Title : Greetings
 Story : A lady worked at a meat distribution factory. One day, when she finished with her work schedule, she went into the meat cold room (Freezer) to inspect something, but in a moment of misfortune, the door closed and she was locked inside with no help in sight.
Although she screamed and knocked with all her might, her cries went unheard as no one could hear her. Most of the workers had already gone, and outside the cold room it's impossible to hear what was going on inside.
Five hours later, whilst she was at the verge of death, the security guard of the factory eventually opened the door.
She was miraculously saved from dying that day.
When she later asked the security guard how he had come to open the door, which wasn't his usual work routine.
His explanation: 'I've been working in this factory for 35 years, hundreds of workers come in and out every day, but you're one of the few who greet me in the morning and say goodbye to me every night when leaving after work.
Today, as you reported for work, like all other days, you greeted me in your simple manner 'Hello'. But this evening after working hours, I curiously observed that I had not heard your 'Bye, see you tomorrow..
Hence, I decided to check around the factory. I look forward to your 'hi' and 'bye' every day because they remind me that I am someone.
عنوان داستان: با سلام
  داستان: خانمی در یک کارخانه توزیع گوشت کار می کرد.  یک روز ، هنگامی که برنامه کاری تمام شد ، او به اتاق سرد نگهداری گوشت( فریزر )رفت تا چیزی را بررسی کند، در یک لحظه متأسفانه ، درب بسته شد و او در داخل گرفتار شدو هیچ کمکی دیده نمیشد.
 اگرچه او با تمام قدرت جیغ می زد ، اما گریه های او شنیده نشد،زیرا هیچ کس صدای او را نمی شنید.  بیشتر کارگران قبلاً رفته بودندو بیرون فریزر نمی توان شنید که در داخل چه می گذرد.
 پنج ساعت بعد ، در حالی که او در آستانه مرگ بود ، سرانجام نگهبان  کارخانه در را باز کرد.
 او در آن روز به طرز معجزه آسایی از مرگ نجات یافت.
 وقتی او بعداً از نگهبان پرسید که چگونه او برای باز کردن در آمده است ، با اینکه این کار همیشگی او نبود.
توضیحات وی: "من 35 سال است که در این کارخانه کار می کنم ، صدها کارگر هر روز وارد و خارج می شوند ، اما شما از معدودکسانی هستید که صبح سلام می کنید و هر شب هنگام خروج از من خداحافظی می کنید.  امروز ، همانطور که برای کار خود گزارش دادید ، مانند همه روزهای دیگر ، به روشی ساده به من سلام کردید.  اما عصر امروز بعد از ساعت کار ، با کنجکاوی مشاهده کردم که"خداحافظ ، فردا می بینمت" را نشنیده ام.
 از این رو ، تصمیم گرفتم در اطراف کارخانه بررسی کنم.  من هر روز منتظر سلام شما هستم زیرا آنها به من یادآوری می کنند که منهم کسی هستم.
زمان کنونی: 01-04-2026، 06:17 PM Persian Translation by MyBBIran.com - Ver: 6.5
