تالار گفتگوی کیش تک/ kishtech forum › پردیس فناوری کیش › کارگاه ، سمینار و دوره های آموزشی v
« قبلی 1 … 25 26 27 28 29 … 45 بعدی »
Stone Machine
Stone Machine
fish57a آفلاین
ارسال‌ها: 11
موضوع‌ها: 11
تاریخ عضویت: Mar 2020
03-03-2020, 03:01 AM
1. Stone Continuous Calibrating Machine
2. Technical data
SAC series Stone continuous calibrating machine
Calibrating head diameter mm 880 1080 1280
Processing width mm 300锝?50 300锝?050 300锝?250
Calibrating head lifting stroke mm 90
Processing thickness mm 10锝?0
Number of calibrating head(Optional) pcs 2/4/6
Water consumption m鲁/h 8/16/24
Power of each calibrating spindle kW 18.5/22
3. Advantage
4. Cooperative Client
The Malaysia local stone factory, one of our big customer named Jason Li, went to our factory with his team introduce by his friend, after negotiate and visit local factory how to use the machine to proceesing, and then he was purchase full set stone cutting machine from Joborn in December 2018.
5. Packing & Loading
Standard export packaging by container, which should be applicable to international requirement.
6. Company profile
Joborn is located in Chinese stone capital - Shuitou. The new factory covers an area of 20000 m2, with the most advanced mechanical processing equipment, warehousing logistics systems, assembly production lines in stone machinery industry. Joborn has a team with more than 150 people of professional research and development, production, sales and service.
7. FAQ
Q: Which side is the slab start to processing for the automatic granite polishing machine?
A: It is depends on customer, if customer want to start from left, we will make it from left and finished in right side.
Q: I want to purchase calibrating machine with more head, how many type you have
A: Yeah, we have three type, with 2heads/4heads/6heads, and the processing width is from 300~1250, depends on your exactly materials require.
Q: Do you provide a detailed maintenance manual?
A: Yes, the maintenance manual will be attached to the machine, as long as follow the manual, basically no problem.
Q: Did you company are one of the "China top ten machinery" ?
A: Yes, we are.
Q: What is the brand of the contactor?
A: We adopt the FUJI brand. Stone Machine
website:http://www.joborn.net/other-stone-machine/
زمان کنونی: 18-03-2026، 03:38 PM Persian Translation by MyBBIran.com - Ver: 6.5
