bulk Water Valve
bulk Water Valve
ysf502595 آفلاین
ارسال‌ها: 10
موضوع‌ها: 10
تاریخ عضویت: Dec 2019
12-12-2019, 06:27 AM
2W160-15:2W160-15 series brass water valve with large orifice type, thread size range from 3/8" to 2", orifice size range from 16mm to 50mm, with thread pipe connection and flange connection types.
Features
1.Protection Degree is IP67, these Valves can be supplied with manual operation.
2.The initial state for normally closed, normally open only for orifice with 16mm, 20mm and 25mm.
Specifications
2W Series Brass Water Valve(Large Aperture)
Model2W160-102W160-152W200-202W250-252W350-352W400-402W500-50
Working MediumAir, Water, Oil, Gas
OperationDirect Drive Type
TypeNormal Close Type
Orifice Size(mm)162025354050
CV Value4.87.612242948
Port SizeG3/8"G1/2"G3/4"G1"G1-1/4"G1-1/2"2
Operation Fluid Viscosity20CST (Below )
Working PressureAir:0~0.1Mpa,Water:0~0.7Mpa,Oil:0~0.9Mpa
MPa / Max Pressure Resistance1.0MPa(normal open type max.pressure 0.8Mpa)
Operating Temperature RangeNBR for -5~80°C and VITON for -5~150°C
Voltage Range±10%
Material of BodyBrass
Material of Oil SealNBR or VITON
ModelABCDK
2W160-10935610669ZG3/8"
2W160-15935610669ZG1/2"
2W160-201005511773ZG3/4"
2W160-251047812599ZG1"
2W160-3514193172124ZG1/4"
2W160-4014193172124ZG1/2"
2W160-50157124195172ZG2"bulk Water Valve
website:http://www.jxpc-machinery.com/valve/water-valve/
  China Auto Solenoid Valve manufacturers g34dfsd 1 1,603 13-04-2020, 06:25 AM
آخرین ارسال: gamegoldfast
  Why You Need a Sanitary Ball Valve? worldnew29 0 1,234 29-08-2019, 09:20 PM
آخرین ارسال: worldnew29
زمان کنونی: 04-05-2026، 07:32 PM Persian Translation by MyBBIran.com - Ver: 6.5
