تالار گفتگوی کیش تک/ kishtech forum › پردیس فناوری کیش › زبان های خارجی › زبان روسی v
« قبلی 1 2 3 4 5 بعدی »
Single Phase EI Core
fangfangfang2 آفلاین
ارسال‌ها: 10
موضوع‌ها: 10
تاریخ عضویت: Sep 2019
09-09-2019, 08:23 AM
ONE PHASE EI SILICON STEEL SHEET WITHOUT HOLE
Introduction:
One phase EI silicon steel sheet without holes, also be called EI core without holes, the main size is from EI19-EI105 in our factory. Grade of raw material: 0.23 mm P085, P090 etc;0.30 mm Q110, Q120 etc; 0.35 mm P135, P155etc; 0.5 mm W1300, W1000, W800, W600, W470, W400 etc, all of the grades mentioned in the technical data. at the same time, we can match Chinese steel according to your steel data.
About the quality, the bur of the core is from 0-0.05 mm, and the width of the core is negative tolerance, such as the order of coils is 90mm, the actual dimension is 89.95mm-90.00mm.
Specifications of steel laminations:
TYPEABCDEFGH
EI1919154.82.434.713.817.73.9
EI28282584617216
EI28A28259.44.654.6515.720.354.65
EI28.228.223.584.74.714.118.84.7
EI303028.584718.523.57
EI30A3025105515205
EI323231.259.54.756.521.7526.56.5
EI32.432.431.61056.221.526.56.2
EI333327.5115.55.516.5225.5
EI33A3333115.55.52227.55.5
EI353529.59.557.519.524.57.5
EI35A3529.211.65.855.8517.523.355.85
EI38.438.43212.86.46.419.225.66.4
EI393932.5136.56.519.5266.5
EI414133136821278
EI424235147721287
EI484840168824328
EI545445189927369
EI575747.5199.59.528.5389.5
EI606050201010304010
EI666654221111334311
EI76.276.263.525.412.712.738.150.812.7
EI85.885.871.528.614.314.3642.957.214.3
EI969680321616486416
EI10510587.53517.517.552.57017.5
Detail:
● Application: Transformer, Electric Reactor etc
● Material: Negotiable
● Payment term: 30% in advance the balance payment according to the copy of B/L by TT; LC
● Delivery date: Negotiable
● Market: Middle East/ Africa/Asia/South America/Europe/North America
● MOQ: 1000KG
● Packing: export standard
a. Carton: 25kg/Ctn (25.2kg-25.3kg gross weight )
b. Package: 1000kg-2000kg/Pallet; 1000kg/Wooden box
c. According to the requirement we have the Fumigation pallets(IPPC)and Non- fumigation pallets
Quality Control
a. We have professional design and maintenance team to keep the mould in excellent conditions.
b. more than 20 quality engineers, most of the process steps need to check at least one time each hour, even in the stamping step, the worker can solve the easy problem by themselves.
c. we can test all kind of transformer according to the bobbins from customers, Advanced and complete testing and inspection equipment as same as the best transformer co and steel co.
d. Strictly control on all raw and auxiliary materials, All raw materials reach the world advanced level.
Parts of customers:Single Phase EI Core
website:http://www.ht-siliconsteel.com/ei-core/single-phase-ei-core/
ziba95 آفلاین
ارسال‌ها: 19
موضوع‌ها: 3
تاریخ عضویت: Oct 2019
30-10-2019, 01:20 PM
(09-09-2019, 08:23 AM)fangfangfang2 نوشته است: ONE PHASE EI SILICON STEEL SHEET WITHOUT HOLE
Introduction:
TYPEABCDEFGH
EI28282584617216
EI30A3025105515205
EI414133136821278
EI424235147721287
EI484840168824328
EI545445189927369
Detail:
● MOQ: 1000KG
Quality Control
خواص و مضرات نخود، موارد منع مصرف و نکات مهم دیگر (تحقیقات جدید)
زمان کنونی: 01-04-2026، 12:29 PM Persian Translation by MyBBIran.com - Ver: 6.5
