تالار گفتگوی کیش تک/ kishtech forum › پردیس فناوری کیش › زبان های خارجی › زبان روسی v
« قبلی 1 2 3 4 5 بعدی »
Mica
Mica
ddwwppyy1 آفلاین
ارسال‌ها: 8
موضوع‌ها: 8
تاریخ عضویت: May 2019
27-05-2019, 07:56 AM
Product Description
Mica is a mineral raw material with outstanding dielectric, thermal and physical properties. Mica sheet consisted of high quality Muscovite and Phlogopite mica paper, impregnated with high temperature resistant organic silicon resin after melting and laminating process. They are the ideal alternative for asbestos insulation, and specially developed for providing outstanding thermal and electrical insulation.
Quick Details
Place of Origin: HeNanChina (Mainland)Brand Name: NewDesen
Model Number: Muscovite PhlogopiteType: Insulation Sheet
Material: Muscovite or PhlogopiteRated Voltage: 20kv
Tensile Strength: 10MpaCondition: Brand new
Thickness: 0.1-100mmWidth: 5mm-1200mm
Length: 5mm-2400mm
Application: High Voltage, High Temperature & Voltage
Packaging & Delivery
Packaging Details:Cartons, or as per customer requirement.
Port;QingDao/ShangHai port
Lead Time:
Storage: Store in a dry and clean room, without being pressed, and keep away from wire or heat or wet, or in the sun.Mica
website:http://www.ndselectricalinsulation.com/mica/
ziba95 آفلاین
ارسال‌ها: 19
موضوع‌ها: 3
تاریخ عضویت: Oct 2019
30-10-2019, 03:14 PM
(27-05-2019, 07:56 AM)ddwwppyy1 نوشته است: Product Description
Quick Details
Length: 5mm-2400mm
Lead Time:
انحراف چشم در بزرگسالان و کودکان، جراحی، هزینه، ورزش ها و درمان طبیعی
ahmed5155002 آفلاین
ارسال‌ها: 6
تاریخ عضویت: May 2020
07-05-2020, 12:24 PM
Spot on with this write-up, I absolutely believe this site needs a lot more attention. I’ll probably be back again to read through more, thanks for the information! You're so interesting 7m! I do not suppose I've read through a single thing like that before. So nice to discover somebody with some original thoughts on this topic. Really.. thank you for starting this up. This web site is one thing that is required on the internet, someone with some originality!
زمان کنونی: 02-04-2026، 09:54 AM Persian Translation by MyBBIran.com - Ver: 6.5
