تالار گفتگوی کیش تک/ kishtech forum › پردیس فناوری کیش › زبان های خارجی › زبان روسی v
« قبلی 1 2 3 4 5 بعدی »
Reduction Gear Box price
ddwwppyy1 آفلاین
ارسال‌ها: 8
موضوع‌ها: 8
تاریخ عضویت: May 2019
27-05-2019, 07:46 AM
Product Overview:
GFB reducer is an ideal speed reducing equipment for swivel table of crawler excavator, rotary drilling rig, auto crane, crawling crane and ship
crane. It can be mounted in equipment directly because of its compact structure. Saving space and convenient to do installation and maintenance Inside structure of GFB reducer adopt our new technology. Installing dimension and main parameters are nearly complete same as Bosch-Rexroth product. So it can be used to replace import product. GFB reducer is not only accord with standard of Bosch-Rexroth product and we can also design
other similar products for replacing reducer of Bravini, Tejin, Nachi and KYB.Because we have strong creating and designing ability,so that we can
provide consulting service to customers and help them to choose the optimal products As per the design requirement, GFB reducer can connect with
fix or variable displacement hydraulic motor of Bosch-Rexroth. When necessary, it can also connect with other hydraulic motors. Multi-disc brake can be installed
at input terminal when necessary. Static braking torque of the brake is matched with input torque of the hydraulic motor (usually static braking torque
is 1.5 times bigger). GFB reducer is widely used on following applications : Wheel crawler excavator. Crawling crane, Rotary drilling rig. Ship
crane GFB reducer has been used by Sany and XCMG. And it also be exported to Southeast Asian, Middle East, India, Korea, Holland and Russia
You are welcomed to buy and wholesale rexroth GFB type planetary gearbox from our factory or check its pricelist and quotation with us, which is one of the brilliant shell rotary speed reducer manufacturers and suppliers.Reduction Gear Box price
website:http://www.nbxhyyoils.com/gearbox/
  Vapingcig, Vaping products, best price! holotwo2019 1 2,357 30-10-2019, 02:56 PM
آخرین ارسال: ziba95
  worm screw shaft price ddwwppyy1 0 1,252 27-05-2019, 07:42 AM
آخرین ارسال: ddwwppyy1
  low price Wood furniture touch up marker ddwwppyy1 0 1,212 27-05-2019, 07:38 AM
زمان کنونی: 29-03-2026، 08:21 PM Persian Translation by MyBBIran.com - Ver: 6.5
