تالار گفتگوی کیش تک/ kishtech forum › پردیس فناوری کیش › نخستین جشنواره بین المللی نمایشنامه نویسی شاهنامه ( به فارسی و زبان های دیگر) v
« قبلی 1 … 3 4 5 6 7 بعدی »
ANSI Loose Flange manufacturers
ysft503 آفلاین
ارسال‌ها: 10
موضوع‌ها: 10
تاریخ عضویت: May 2019
22-05-2019, 12:26 PM
EO Flanges can provide ANSI B16.5 Class 600 Lap Joint Flanges, which Length Thru Hub from 0.88 to 7.25 in, Hub Diameter from 1.5 to 28.25 in, Radius from 0.13 to 0.5 in, etc. Our factory land size over 15000 square meters, and capacity 3600MT per year. We approved by  ISO9001, TUV, PED, CCS, ABS, DNV, LR, BV. Our products have been widely used and recognized, you can choice with safely.
Nominal Pipe SizeOutside Diameter (O)Thickness (T)Length Thru Hub (Y)Hub Diameter (X)Radius (r)Bore (B)Approximate Weight (lbs)Bolt Circle (C)Number of HolesDiameter of Holes
1/23.750.560.881.50.130.922.6340.63
3/44.630.6311.880.131.1133.2540.75
14.880.691.062.130.131.3843.540.75
1 1/45.250.811.132.50.191.7253.8840.75
1 1/26.130.881.252.750.251.9774.540.88
26.511.443.310.312.469580.75
2 1/27.51.131.633.940.312.97125.8880.88
38.251.251.814.630.383.6156.6380.88
3 1/291.381.945.250.384.1207.2581
410.751.52.1360.444.6368.581
5131.752.387.440.445.696110.581.13
6141.882.638.750.56.757811.5121.13
816.52.19310.750.58.7511013.75121.25
10202.54.3813.50.510.9217017161.38
12222.634.6315.750.512.9220019.25201.38
1423.752.755170.514.1825020.75201.5
162735.519.50.516.1936523.75201.63
1829.253.25621.50.518.243525.75201.75
20323.56.5240.520.2557028.5241.75
2234.253.756.8826.250.522.2567030.63241.88
243747.2528.250.524.2581033242
Packaging & Delivery
Packaging Details: ANSI B16.5 class 600 lap joint flanges Playwood cases or pallets
Delivery Detail: According order quantityANSI Loose Flange manufacturers
website:http://www.eoflange.com/ansi-b16-5-flanges/ansi-lap-joint-flanges/
زمان کنونی: 03-04-2026، 10:22 PM Persian Translation by MyBBIran.com - Ver: 6.5
