تالار گفتگوی کیش تک/ kishtech forum › پردیس فناوری کیش › نخستین جشنواره بین المللی نمایشنامه نویسی شاهنامه ( به فارسی و زبان های دیگر) v
« قبلی 1 … 3 4 5 6 7 بعدی »
Aluminum Foil Bag suppliers
ysft503 آفلاین
ارسال‌ها: 10
موضوع‌ها: 10
تاریخ عضویت: May 2019
22-05-2019, 12:16 PM
Product NameAluminum Foil Food Bag With Printing
SizeCustomized
ColorCustomized
LogoCustomized
MaterialAluminum Foil
Place Of OriginLiaoning, China
We are manufacturer of Aluminum Foil Food Bag With Printing. A high quality bag will enhance your brand awareness and upgrade your corporate image.
Usage: Snack, milk powder, beverage powder, nuts, dried food, dried fruit, seeds, coffee, sugar, spice, bread, tea, herbal, wheat, cereals, tobacco, salt, flours, pet food, candy, rice, confectionaries etc.
Aluminum foil has been widely used in the following industries, based on its excellent performance and continuous progress in manufacturing technology.
Beverage industry: Composite packaging made of aluminum foil, paper, PE and other multi-layer materials is an ideal packaging material for the long term, low cost and small impact on environment in the world. The quality indexes of aluminum foil, such as surface quality, pinhole, unfolding performance and so on, have great influence on the freshness and appearance of the beverage packaging, so the quality of the packaging of the soft drinks is very strict.
Soft Packaging: With the improvement of people's living standard and the Quickening of life rhythm, the food supply mode has changed, the convenience food with long freshness is more and more. Products are rolled and block packaging. Used in food cooking for freezing, fresh, baking and so has a very good role in the refrigerator or freezer, can be wrapped in aluminum foil food, aluminum foil can maintain its shape, can avoid fish, vegetables, fruits, dishes of water loss, and to prevent the taste of the external discharge or mixing, both sanitary and convenient. The steel grating factory uses the aluminum foil to separate the high temperature charcoal fire and smokes, may avoid the food to scorch causes the carcinogenic substance, is the healthier edible method. This product is in line with the National food hygiene standards, and with cutting saw blades of color box packaging, easy to use, beautiful and generous.
A gravure printing operation procedure
Stop the main motor, printing base material stop feeding. Embossing Roller lifting, scraper out of print layout, stop the ink pump, pour out the remaining ink, clean the printing plate surface, until there is no residual printing ink, take off the printed base material, turn off the dryer electric heating.
Clean the ground, when the printing plate is no longer used, the plates removed, both ends, placed on a dedicated plate rack. If not in the long term, then the package is placed in the warehouse. A group of rollers should be put together to avoid disruption, the outside should be labeled, and indicate how many impressions have been printed for use at any time. Aluminum Foil Bag suppliers
website:http://www.eogreenbag.com/food-storage-bags/aluminum-foil-bag/
زمان کنونی: 03-04-2026، 01:53 PM Persian Translation by MyBBIran.com - Ver: 6.5
