تالار گفتگوی کیش تک/ kishtech forum › پردیس فناوری کیش › نخستین جشنواره بین المللی نمایشنامه نویسی شاهنامه ( به فارسی و زبان های دیگر) v
« قبلی 1 … 3 4 5 6 7 بعدی »
MITSUBISHI Diesel Generator price
ysft503 آفلاین
ارسال‌ها: 10
موضوع‌ها: 10
تاریخ عضویت: May 2019
22-05-2019, 12:14 PM
Product Name: 1500 KVA MITSUBISHI Diesel Generator Set
Model NoTongueFS1500
Prime Power(kVA/kW):1500/1200
Standby Power(kVA/kW):- / -
Engine Model:S12R-PTAA2
Engine Brand:MITSUBISHI
PFS Series 1500 KVA MITSUBISHI Diesel Generator Sets are powered by Mitsubishi engines and Mitsubishi turbochargers, which are engineered and manufactured in the same facility. It is certain to result in the high productivity and improved fuel economy diesel generator Mitsubishi engine, under the same cubic capacity with much higher output power and much better environmental protection performance have been the representative particular for heavy duty diesel generating sets application. Every unit is inspected and tested before leaving the factory and the test report is sent with the Gen Set.
Prime Power: 1200kW(1500kVA)
Standby Power: kW(kVA)
Frequency: 50HZ
Engine Maker: Mitsubishi
Engine Model: S12R-PTAA2
Cylinder Arrangement: 12V
Aspiration: Turbocharge
Governing Tpye: Electric
Fuel Consumption:
100% Load: 330 L/h
75% Load: N/A L/h
50% Load: N/A L/h
Easy adaptation to meet the various needs of matched equipment, according to the requirement of users.
Mitsubishi Generator set features include steady and reliable, high shock resistance, strong load resistance, sufficient output power, low emissions, easy and cheap maintenance.
High quality cast iron and specially designed valve guide ensures sealing performance and durability
40 centigrade radiator as standard, Oil cooler and Drain tap
12/24V starting motor and charge engine.Extremely low oil consumption
Features Benefits
Powered by Mitsubishi engineFunction stability credibility
Tightly structure, excellent design and craftBeautiful appearance
High durability at maximum performanceLow life cycle operating cost results in optimal economy
Excellent cooling system, reliable operation under harshest conditions (ambient temperatures up to 40°C and altitudes up to 1000 m)Gets the job done wherever you are
Key start or auto start (by LCD) type of modulesAllows complete control, easy connecting, ease of operation
Optional sound attenuated enclosures availableEase of installation, operation, and maintenance
Designed with safety in mind Earth leakage protectionQuick fix electrical power connectionsSafety first
Extensive option list.Customization
A Full load test is conducted at 25%, 50%, 75%, 100% and 110%Good quality ensure
More:
As a professional manufacturer and designer of 1500 KVA MITSUBISHI Diesel Generator Set, we can offer various kinds of 1500 KVA MITSUBISHI Diesel Generator Set With advanced mechanical equipments and experienced technical workers that we can provide 1500 KVA MITSUBISHI Diesel Generator Set on top quality and best price. The 1500 KVA MITSUBISHI Diesel Generator Set will be shipping from China factory directly to your offered address. We are confident to be the best 1500 KVA MITSUBISHI Diesel Generator Set supplier in China.MITSUBISHI Diesel Generator price
website:http://www.eohic.com/diesel-generator/mitsubishi-diesel-generator/
  Water Soluble Fertilizer price ysft503 0 959 22-05-2019, 12:28 PM
آخرین ارسال: ysft503
زمان کنونی: 13-12-2025، 01:21 PM Persian Translation by MyBBIran.com - Ver: 6.5
