تالار گفتگوی کیش تک/ kishtech forum › پردیس فناوری کیش › زبان های خارجی › زبان انگلیسی v
« قبلی 1 … 18 19 20 21 22 بعدی »
Seamless Structure Pipe factory
safzxbv111 آفلاین
ارسال‌ها: 10
موضوع‌ها: 10
تاریخ عضویت: Jan 2019
18-01-2019, 06:00 AM
Seamless steel pipe with GB/T8162 Q345C lower tempreature
Q345 steel pipe have good comprehensive mechanical properties,Low Temperature performance can also,Plasticity and weldability is good, apply to the low pressure vessel, oil tank, vehicles, cranes, mining machinery, power stations, Bridges,Can be used in various structure below 40 ℃ cold areas.
Q345A Chemical composition
C≤0.20  Mn 1.0~1.6   Si≤0.55   P≤0.045   S≤0.045   V 0.02~0.15
Tensile strength(mpa):490-675
proof stress(mpa):≥345
Elongation(%):≥21
Q345B Chemical composition
C≤0.20   Mn 1.0~1.6   Si≤0.55   P≤0.040   S≤0.040   V 0.02~0.15
Elongation(%):≥21
Q345C Chemical composition
C≤0.20   Mn 1.0~1.6   Si≤0.55   P≤0.035   S≤0.035   V 0.02~0.15   Al≥0.015
Elongation(%):≥21
Q345D Chemical composition
C≤0.18   Mn 1.0~1.6   Si≤0.55   P≤0.030   S≤0.030   V 0.02~0.15   Al≥0.015
Elongation(%):≥22
Q345E Chemical composition
C≤0.18   Mn 1.0~1.6   Si≤0.55   P≤0.025   S≤0.025   V 0.02~0.15   Al≥0.015
Elongation(%):≥22
Q345A,Q345B,Q345C,Q345D,Q345E
Their impact of temperature is different
Q345A--- Do not impact
Q345B---20 degrees temperature impact
Q345C---Zero impact
Q345D--- - 20 degrees impact
Q345E--- - 40 degrees impact
Specification:
1. Out Diameter: 21.3mm - 800mm
2. Thickness: 0.6mm -120.0mm
3. Steel Grade: Q195-Q345, 10#-45#, ST35,ST45,ST52, 1010,1045,4130,4140
4. Standard: GB/T 3091-2001, BS1387-1985, DIN EN10025, EN10219, ASTM SCH40, ASTM SCH80
5. Surface Finish:  Galvanized, electro galvanized, black
6.Length: 5-15m maximum
7. Process Method: HOT ROLLED or HOT EXPANSION
8.Pipe Ends: Square cut or bevelled
Package: Suitable packing according to the size of the pipes.
Supply Ability: 3000 metric tons per month.
My company has many STOCK of Q345 seamless pipes. about 15000tons, the pipes is from TPCO, ANGANG, BAOSTEEL, Baotou  melong, Fengbao etc.
Exports to Europe, North America, the Middle East, Africa, Asia and other countries and regions.Seamless Structure Pipe factory
website:http://www.galaxy-steel.com/seamless-steel-pipe/seamless-structure-pipe/
  Parking Lot Stainless Steel Drain Cover factory dsfsfb1v 0 1,423 09-01-2019, 01:33 PM
آخرین ارسال: dsfsfb1v
  China Polycarbonate Solid Corrugated Sheets factory dsfsfb1v 0 1,165 09-01-2019, 01:30 PM
  Foshan Glass Mosaic Tile factory dsfsfb1v 0 1,162 09-01-2019, 01:28 PM
زمان کنونی: 02-04-2026، 11:46 PM Persian Translation by MyBBIran.com - Ver: 6.5
