تالار گفتگوی کیش تک/ kishtech forum › پردیس فناوری کیش › زبان های خارجی › زبان انگلیسی v
« قبلی 1 … 18 19 20 21 22 بعدی »
China Lead-free Brass Press Unions manufacturers
safzxbv111 آفلاین
ارسال‌ها: 10
موضوع‌ها: 10
تاریخ عضویت: Jan 2019
18-01-2019, 05:57 AM
1.Product Description:
● Fast and easy to use
● Helps installers easily identify unpressed connections during pressure testing
● Minimizes system downtime by allowing for wet connection
● No flame,solder, flux, or heavy equipment needed
● Press joining makes secure connection in less than 7 seconds
2.Product Specification:
Item No. ID Material Certification Pcs/bag
70209500 1/2" C46500/ C69300 UPC
NSF/ANSI 61
NSF/ANSI 372 1
70209600 3/4" 1
70209700 1" 1
70209800 1-1/4" 1
70209900 1-1/2" 1
702010000 2" 1
3. Press Joining Method:
Press joining is a form of mechanical connection for copper and steel tubing which uses a press tool, jaws, and rings to affix the sealing element and fitting to the tubing.
Press copper joining systems offer a high quality installation that is faster and cleaner than traditional solder. Press copper joining provides a reliable long lasting installation both above and below ground. The tubing should be fully inserted into the fitting, and the press made according to manufactures instructions, using the press tool, jaws and rings reommended by the manufacturer. For applications other than domestic water contact the fitting manufacturer.
Press joining for stainless steel pipe provides a fast, easy, clean and reliable means for installing 1/2"-2" (15-50mm) stainless steel piping systems. Press joining requires no flame or arcs as with welding; no cutting oil, chips or preparation time as with threading or flanging.
4. Accessory:
EPDM sealing element
5. Installation Instruction:
1. Cut the Tube
An appropriate copper tube cutter must be used to ensure a clean square cut. Note: It is important that the copper tube is cut completely square, the end of the tube (outside) must be clean and free from any scratches or damage such as dints or deformity.
2. Remove Burrs
Make sure that the internal and external tube end is completely free from burrs or sharp edges by using a file or deburring tool. Note: ensure over use does not affect the tube end outside diameter.
3. Inspect the Fitting
Before inserting the tube, check O-rings (15-50mm) and also spacers/grab rings (65-100mm) for correct placement, they are free of damage or any dust, dirt or debris. We recommend the fittings are retained in packaging up to the point of use where ever possible.
4. Making Insertion Depth on Tube
All cut and deburred copper tube ends for insertion into the fitting require an insertion depth make to be applied to the tube prior to insertion into the fitting. The mark will be applied by measuring from the end of the tube with a ruler or tape measure and using a marker pen to the required length. The mark will ensure the tube is inserted completely into the fitting prior to press.
5.Tube Insertion
The tube should be inserted parallel into the fitting coupling ensuring no damage is caused to the O-ring or grab ring and spacer (DN65-100mm0, ensuring the insertion mark is visible at the end of the fitting next to the fitting coupling end.
6.Press Tool Selection
The tool to be used must be conformant, well maintained and within its manufactures service requirement. The correct jaw type and size must be inspected to ensure it is clean and free from defects and contamination.
7.Press the Joint
The jaw must be placed over the fittings, correctly aligned and positioned. When all requirements are correct, the tool should be activated to press the joint. The tool should complete the correct cycle and the jaw ends should fully close on completion. If the tool does not complete the required cycle during operation the fitting must be cut out, replaced then repressed. No fitting should be pressed more than once. Tooling should be used as per its respective manufacturers’ documented requirements.
8.Joint Completion
The fitting should be inspected after pressing to ensure the correct press has been performed and no cracking or over deforming has occurred. The pipe insertion mark should be checked and be at the fitting edge, to ensure it has not moved.(DN65/DN80/DN100 has a sticker on each fitting that can be removed after press and inspection to ensure conformance).
6. Minimum Soldering Distance Table:
The minimum distance when making a press joint near a solder is in the table below. No residual solder, flux, or debris should be on the tubing.
Tube Dia. Minimum Distance Tube Dia. Minimum Distance
1/2" 1-1/2" 1-1/4" 3-3/4"
3/4" 3-1/4" 1-1/2" 4-1/2"
1" 3" 2" 6"
7. Pressing tool and jaws:
8. Recommendations:
Fada Lead-free Brass Press Female Union, FPT x P
Fada Lead-free Brass Press Male Union, MPT x P
9. Frequently Asked Questions:
Q:Can this brass press union be installed in a refrigeration system?
A: No. The EPDM seals are not compatible with refrigerants, and the pressure rating of the system is not sufficient for many refrigerant gases.
Q: Can the Press Fittings’ connection be re-crimped?
A: Yes. Only to make sure, the pressing jaws must be positioned on the same hex flats as the
original crimp.
Q: What’s the minimal order quantity for this series of product?
A: In fact, it depends on which size do you need. For instant, 12" requires 3000 and 1" will be 2000pcs at least. For more details, please contact with our sales personnel.
10. About us:
Our Product line: Brass & Bronze Fittings; Brass & Bronze Valves; Brass Faucet; Floor Drain
With a thirty years history of supplying Brass & Bronze Fittings and Valves, Taizhou Bada Valve Co.,Ltd has presented leadership in Brass & Bronze Fittings and Valves Manufacturing Industry. To keep making progress everyday, we never stop asking “What makes us different?"
Because we’re dedicated to quality in everything that we do, it’s no surprise that we’ve been able to partner with industry associations of the highest standards. We use the finest raw materials available, put them through a thorough manufacturing process, and conduct rigorous testing to ensure that every product we provide is dependable, durable, and long-lasting.
11. Location:
♦ Headquarters
Fengjiang, Luqiao District, Taizhou City
Zhejiang Province, China
Zip Code: 318054
♦ Factory
No. 7, industrial road, Luohe Industrial Park, Guixi, Yingtan
Jiangxi Province, China
Zip Code: 335400
12. Contact Us:
sales6@badavalve.com
+86-576-82686004 China Lead-free Brass Press Unions manufacturers
website:http://www.cnfadavalve.com/lead-free-brass-fittings/lead-free-brass-press-unions/
  Free was the most-penalized offensive tackle in the Madden NFL 24 Nevillberger 0 2,677 17-01-2024, 01:03 PM
آخرین ارسال: Nevillberger
  LED Flood Light Fixture For Warehouse manufacturers fish29fi 0 1,258 01-08-2019, 08:41 AM
آخرین ارسال: fish29fi
  China 5 Inch By Crimped Cup Brush Carbon Steel fish29fi 0 1,028 01-08-2019, 08:37 AM
  China Knee Sock For Men manufacturers fish29fi 0 960 01-08-2019, 08:35 AM
  China Load Cell fish29fi 0 957 01-08-2019, 08:29 AM
  Facial Cleansing Brush China fish29fi 0 1,012 01-08-2019, 08:28 AM
  Itlay Type Cable Reel Made in China fish29fi 0 1,001 01-08-2019, 08:27 AM
  China 7 Coupling fish29fi 0 960 01-08-2019, 08:26 AM
  1 Water Level Control Valve manufacturers safzxbv111 0 1,483 18-01-2019, 06:07 AM
آخرین ارسال: safzxbv111
  Direct Garden Eva Clogs Free Sample safzxbv111 0 1,662 18-01-2019, 06:05 AM
زمان کنونی: 30-03-2026، 04:43 AM Persian Translation by MyBBIran.com - Ver: 6.5
