CNC Machine
CNC Machine
Wyz09hx آفلاین
ارسال‌ها: 10
موضوع‌ها: 10
تاریخ عضویت: Dec 2018
20-12-2018, 11:27 AM
2016 CustomTop Quality cnc precision machined parts With factory price
Quick Details
CNC Machining or Not: CNC Machining
Type: Drilling, Laser Machining, Milling, Other Machining Services, Rapid Prototyping, Turning, Wire EDM
Material Capabilities: Aluminum, Brass, Bronze, Copper, Hardened Metals, Precious Metals, Stainless Steel, Steel Alloys
Micro Machining or Not: Micro Machining
Place of Origin: Shanghai, China (Mainland)
Model Number: NTC-2015031502
Brand Name: ntc
Material: Brass,Aluminum, stainless steel, carbon steel
Size: According to drawing
Color: Gold
Tolerance: +/-0.01mm
Surface Treatment: Polishing,anodization,plated,etc
Processing Way: High Precision CNC machining
Making Samples Time: 5-15days
Test Equipment: CMM,Tool microscope,projector,Height Gauge,...
Application: Auto Part/Water Plumbing/Board/Hardware...
Service: After-sale Service
Brand Name: NTC
Model Number: NTC2016021502
Application: Specifications
CNC Lathe Metal Parts
CNC Metal parts, CNC Lathe parts, Machined parts, CNC parts, Precision Machining parts, OEM/ ODM, Anodize
CNC Metal parts, CNC Lathe parts, Machined parts, CNC parts, Precision Machining parts, OEM/ ODM, Anodize, Oxide, Bead blasting, Various Electron Plating and surface treatments
CNC Lathe metal parts can be machined with tiny tolerance, precise dimensions and a smooth surface. Roughness is typically considered to be the high frequency, short wavelength component of a measured surface. That’s why most of RF Connector is machined by CNC instead of die-casting.
Product Description
Not CNC Machining CNC Machining or Not cnc machined brass parts
China factory direct
Low MOQ
Sample available
OEM design
Item Name
Material
Brass
Surface Treatment
Tolerance
+/-0.01mm
Machining Processing
CNC machining
Making Samples Time
5-15days
Standard DIN,JIS,ASTM,AISI,BS,GB
ODM&OEM service are all welcomed
Practicable Software: Solidworks,Pro/Engineer,Auto CAD,PDF,JPG
Mold Making Time: 15-35 days
Mold Life Time: 500000-1000000pieces
Our Advantage:
1.Competitive price.
2.Continuance service and support.
3.Diversified rich experienced skilled workers.
4.Custom R&D program coordination.
5.Application expertise.
6.Quality,reliability and long product life.
7.Mature,perfect and excellence,but simple design.
After sales services:
Spare parts offering, like: spring, ejector pins…
Mould maintenance as much as possible
Some inserts or plate for cost payment
Mould and part design available
Products applications:
Household utility ware,auto components,Computer electronics
Electronics components,Marketing samples,Medical & dental products
Model shops, toys, hobby,New product design & development,Furniture Design
Civil Engineering,Construction,Marine Industry,Garden Products,Military industryCNC Machine
website:http://www.ntccasting.com/cnc-machine/
  China Shot Blasting Machine factory ysf502595 0 993 12-12-2019, 06:22 AM
آخرین ارسال: ysf502595
  professional packing machine in stock Wyz09hx 0 998 20-12-2018, 11:23 AM
آخرین ارسال: Wyz09hx
زمان کنونی: 23-03-2026، 06:31 AM Persian Translation by MyBBIran.com - Ver: 6.5
