1 2 3 4 5 … 81 بعدی »
MMOexp Borderlands 4: Disable the Forcefield and Defeat Smiley Man
Stellaol آفلاین
ارسال‌ها: 3
موضوع‌ها: 3
تاریخ عضویت: Nov 2025
04-11-2025, 12:19 PM
Return to Borderlands 4 Boosting the maze's entrance and follow the carrots scattered along the ground. Each batch points in the direction you should take next. Keep tracking them carefully, and you'll eventually reach the glowing exit door.
As you step out, confetti bursts overhead, and Smiley offers sarcastic applause. He instructs you to "claim your prize," but when you enter the next room, the floor drops again, hurling you into the final deadly test.
Final Challenge: Disable the Forcefield and Defeat Smiley Man
You awaken in a dimly lit chamber filled with glowing green tubes - and Smiley Man himself stands tauntingly on the other side of a forcefield. Without warning, he releases toxic gas, forcing you to act quickly.
Step 1: Look up and to the right - there's a vent door you can pull open with your grapple.
Step 2: Inside the vent, shoot the glowing power mechanism to disable both the gas and the forcefield.
As the power flickers out, approach Smiley Man. He'll try to talk his way out of it, suggesting a "business partnership" and leading you toward an exit corridor. But before you can follow him, his own trap backfires: the security door slams shut, and he's roasted alive inside - a gruesome but fitting end for the sadistic showman.
Mission Completion and Rewards
With Smiley's demise, a side door opens, revealing a narrow passage leading to a lift. Ride it up to the surface to officially complete the No-Escape Room side mission.
You'll automatically receive XP, cash, and a random weapon (ranging from Uncommon to Epic quality). Check your Inventory afterward - you'll also find a reward chest containing the Eternal Defender vehicle paint job, a sleek metallic finish for your ride.
Tips for Success
Search carefully for ECHO Logs. They not only simplify puzzles but also expand the dark lore behind Smiley Man's twisted experiments.
Use your grapple liberally. Many clues and vent paths are placed above eye level.
Watch environmental cues. Bloodstains, vegetables, and item placements all subtly point you toward correct solutions. The right amount of cheap Borderlands 4 Money will also help you find the answer.
Play with audio on. Smiley's taunts sometimes hint at puzzle logic or hidden shortcuts.
Final Thoughts
The No-Escape Room is a standout among Borderlands 4's many side missions - a mix of puzzle-solving, psychological horror, and the franchise's trademark humor. It's equal parts eerie and entertaining, rewarding players who pay attention to detail rather than brute-forcing every encounter. Whether you approach it for the loot, the laughs, or the lore, one thing's certain: once you're trapped in Smiley Man's playground, you'll never look at "escape rooms" the same way again.
In Borderlands 4, the wastelands are filled with chaos, loot, and unexpected moments of quiet reflection. The side mission "Returned to the Mountain" is one of those rare moments-a brief but meaningful story about honor, remembrance, and loyalty among the Defiant.
Defiant Calder, a proud yet humble warrior, tasks you with retrieving the sacred bolts of his fallen brethren. These bolts represent their connection to the mountain, a symbolic resting place for Defiant warriors who've died in battle. What begins as a simple recovery quest turns into a touching look at sacrifice and tradition in the Borderlands universe.
This walkthrough covers everything you need to know to complete "Returned to the Mountain," including how to start it, where to find each bolt, enemy encounters, and the rewards waiting for you at the end.
How to Start "Returned to the Mountain"
You'll unlock this quest in the mid-to-late stages of Borderlands 4, shortly after completing the main story mission "Ash and Honor." Once you've finished that mission, head to the Highspire Peaks area. Near the cliffside outpost, you'll find Defiant Calder, standing solemnly by a makeshift memorial of scrap metal and glowing crystal shards.
Speak with Calder to trigger a short dialogue sequence. He'll explain that several of his fellow Defiant warriors fell during a desperate last stand against the Children of the Ruin. Their bodies remain scattered across the mountains, and their bolt-power cores infused with their essence must be recovered and returned to cheap Borderlands 4 Boost the mountain for a proper send-off.
زمان کنونی: 11-04-2026، 03:51 AM Persian Translation by MyBBIran.com - Ver: 6.5
