تالار گفتگوی کیش تک/ kishtech forum › پردیس فناوری کیش › گروه رشته های مدیریت › مدیریت دولتی v
1 2 3 4 5 بعدی »
MMOexp Poe 2 for high critical strike
BennieJack آفلاین
ارسال‌ها: 3
موضوع‌ها: 3
تاریخ عضویت: Sep 2025
17-09-2025, 01:14 PM
The passive skill tree in POE2 allows you to further enhance your build through a combination of elemental damage nodes, projectile damage, critical strike chance, and survivability. As a Lightning Spear Huntress, you'll want to focus on the following key areas:
Elemental Damage: Since Lightning Spear deals lightning damage, prioritize elemental damage nodes that increase lightning and elemental damage.
Projectile Damage: Given that Lightning Spear is a projectile skill, increasing projectile damage and projectile speed will significantly boost your DPS and make it easier to hit distant enemies.
Critical Strike Chance and Multiplier: As the build relies heavily on critical hits, getting critical strike nodes that boost both chance and multiplier is essential for maximizing your damage output.
Life and Evasion: The Huntress excels at avoiding damage through evasion, so picking up nodes that boost evasion, life, and energy shield is crucial for survivability. Don't forget to also pick up life leech nodes, especially if you're focusing on sustained combat.
Mobility and Speed: Huntresses are known for their agility. Pick up nodes that increase your movement speed, as this will help you dodge attacks while maintaining your high DPS.
Gear and Stat Priorities
Your gear choices are critical for enhancing the Lightning Spear Huntress build's effectiveness. Since this build relies on high elemental damage and critical strikes, prioritize the following stats when selecting your gear:
Increased Lightning Damage: Look for gear that enhances your lightning damage, whether through flat bonuses or percentage increases.
Critical Strike Chance and Multiplier: Aim for high critical strike chance on your weapons and accessories. Critical strike multiplier also dramatically boosts your damage.
Projectile Damage: Ensure that your gear boosts projectile damage, as this will directly benefit your Lightning Spear skill.
Energy Shield and Evasion: Focus on acquiring gear that provides both energy shield and evasion to stay resilient while moving and evading attacks.
Mana Regeneration or Efficiency: Since Lightning Spear can be a heavy mana user, items that increase your mana regeneration or efficiency will prevent you from running out of resources in the heat of battle.
Poe 2 trade was amazing. He made my deal go seamlessly. He was professional and friendly. Would absolutely buy from again! You can also purchase it at MMOEXP.com
  MMOexp New World have distinctive appearances BennieDe 0 437 18-09-2025, 08:02 AM
آخرین ارسال: BennieDe
  MMOexp Diablo4 during intense world events BennieDe 0 338 18-09-2025, 08:00 AM
  MMOexp New World into a region with hostile wildlife BennieJack 0 335 17-09-2025, 01:13 PM
آخرین ارسال: BennieJack
  MMOexp Diablo4 to understand the deeper forces BennieJack 0 330 17-09-2025, 01:11 PM
زمان کنونی: 07-11-2025، 09:31 AM Persian Translation by MyBBIran.com - Ver: 6.5
