4 ساعت پیش
To access and use Peacock TV on a Samsung Smart TV, follow these steps:
[*]Check for Compatibility:
[*]Ensure your Samsung Smart TV is running a Tizen OS version that supports the Peacocktv.com/tv app. Most 2017 models and later should be compatible.
[*]Download the Peacock TV App:
[*]Press the Home button on your remote to open the Smart Hub.
[*]Navigate to the Apps section and search for Peacock .
[*]Once found, select the app and press Install .
[*]Log into Your Peacock Account:
[*]After installation, open the Peacock app from your home screen or apps menu.
[*]Sign in using your Peacock account credentials (or create one if you haven't already).
[*]Start Watching:
[*]Browse through the content categories or use the search function to find something you want to watch.
[*]Select and start streaming!
[*]No App Found: If the app is not available, make sure your TV's software is up to date. You can check for updates in the settings under "Support" > "Software Update."
[*]App Crashing or Not Opening: Try restarting the TV or reinstalling the app.
If you're trying to access Peacock.com/tv on a Samsung mobile device, simply download the app from the Google Play Store and log in as you would on other devices. Let me know if you need more details!
[*]Start Watching:
Troubleshooting:
[list][*]No App Found: If the app is not available, make sure your TV's software is up to date. You can check for updates in the settings under "Support" > "Software Update."
