Step-by-step Guide to Watching Vudu on Amazon Fire Stick Devices - نسخهی قابل چاپ +- تالار گفتگوی کیش تک/ kishtech forum (http://forum.kishtech.ir) +-- انجمن: پردیس فناوری کیش (http://forum.kishtech.ir/forumdisplay.php?fid=1) +--- انجمن: سامانه آموزش آنلاین رهیاران (http://forum.kishtech.ir/forumdisplay.php?fid=209) +--- موضوع: Step-by-step Guide to Watching Vudu on Amazon Fire Stick Devices (/showthread.php?tid=97118) |
Step-by-step Guide to Watching Vudu on Amazon Fire Stick Devices - hensen5005 - 02-10-2024 Watching Vudu on your Amazon Fire Stick device is fairly straightforward and should only take a minute or two. Here are the steps you should follow to watch shows and movies on Vudu with Fire Stick. 1. Setup Amazon Fire Stick & Download Vudu
After your Amazon Fire Stick device is all set up, you'll need to download the Vudu.com/start app. From the home screen, click on the search, and look up Vudu. Then click the app and download.
2. Create an account with Vudu
Once you have the Vudu app installed on your device, you'll need to create an account. The account sign up requires a name and email address. You'll also be prompted to enter your payment info (Vudu accepts cards and PayPal).
Depending on the device you use, you might need to sign up for a Vudu account through the Vudu website instead of your device. But the signup process is fast and should only take a few minutes.
3. Start Watching
After you have Vudu.com start code downloaded on your device and an account created, you'll be able to watch free content on the platform. If you want to buy or rent a movie or a show, you do it through Vudu, and your payment will be automatically processed.
If you buy a movie or show, you'll be able to watch it through Vudu whenever you want. And if you're away from home, you can always access your Vudu account using a web browser or with a mobile app. The Vudu mobile app is available for both iOS and Android.
