تالار گفتگوی کیش تک/ kishtech forum › پردیس فناوری کیش › همایش بین المللی نقش مشاوره در راهبرد مدیریت توسعه و رشد اقتصادی و صنعتی در ایران v
« قبلی 1 2 3 4 5 … 10 بعدی »
Jacob & Co. Astronomia Tourbillon Icy Blue Sapphires
maradiliko آفلاین
ارسال‌ها: 4
موضوع‌ها: 4
تاریخ عضویت: Mar 2022
19-12-2022, 11:09 AM
The Jacob & Co. Astronomia Tourbillon Icy Blue Sapphires is the supreme 21st one hundred year ultra-high-end horological industry and a worldwide recognized image of Jacob & Corp watchmaking knowledge. A world-first both in the particular boldness for its unheard of concept as well as entirely physical construction, typically the Astronomia moved beyond outstanding horological successes and has recently been regarded as a first-rate multidisciplinary architectural achievement.
The actual Jacob and Co. Astronomia Tourbillon Frozen Blue Sapphires represents the actual essence about Astronomia: this can be a cinematic statue animated simply by its four-arm movement design that turns and floats through the sapphire-bound space inside of its astonishing case. Packed with unparalleled watchmaking solutions in addition to adorned having exceptional concluding techniques, often the Astronomia Tourbillon has attained its status as an expert icon in the field of haute horlogerie. https://www.perfectwrist.ru
https://www.perfectchrono.ru
https://www.fashionreviewprice.com
https://www.perfectchrono.co
https://www.perfectwrist.co
https://fashiontourbillon.com
[تصویر:  450.CI.1100.RX.FWC22.jpg]
The several arms in the Astronomia Tourbillon carry the exact triple-axis tourbillon timekeeping wood of the observe, the magnesium globe with hand-painted purple for a sensational representation of Planet Earth, the very exclusive Jacob-Cut 1-carat stone with 288 facets, as well as the differential-leveled, skeletonized time present. This four-arm assembly finishes a revolving around the centre of the look at and over an outstanding backdrop around 20 mins. Another incredible feature on the Astronomia Tourbillon is just how each couple of opposing forearms are flawlessly calculated counterweights of one one more - any testament to peerless supplies engineering and monitor movement design and style. By having identical weights regarding these other arms, it is axles are usually relieved coming from strain plus increased take, as the movements takes up diverse orientations on space.
Whilst the tourbillon was actually invented as a single-axis, spinning cage to hold the unsafe effects of organ of your mechanical bank account watch for increased timekeeping efficiency, the Astronomia Tourbillon delivers this 224-year-old invention in order to breathtaking degrees of modern accomplishment and difficulty.
The triple-axis tourbillon with the Jacob and also Co. Astronomia Tourbillon Frigid Blue Sapphires is at the main forefront of recent watchmaking. The particular triple-axis tourbillon’s delicately furnished cage encapsulates the balance tyre, hairspring, avoid wheel and also a number of additional crucially crucial components. Seen as this openworked cage, this specific outstanding tourbillon rotates at three axes simultaneously. This can be a constellation associated with superbly done components that will, when built and fine-tuned expertly, permits the JCAM10 to keep correct time through its 60-hour power reserve.
The full rotation on the 1st axis takes specifically 60 seconds, as being a nod to the traditional single-axis tourbillon. Another axis regarding rotation demands 5 minutes to finish, while the 1 / 3 axis involving rotation was made possible by the 20-minute, four-arm twisting platform of your Astronomia Tourbillon. This makes to get a bold new image at how tourbillons can perform, when manufactured with hi-tech, ultra-modern systems and ageless horological history in mind.
Typically the based dial of this timepiece is invisibly set by using 257 Kuvertbr?d Icy Azure Sapphires (≈ 9. 88 ct. ). In spectacular timepieces such as, matching the stones is extremely important this means you will take up to 3 years to locate exactly the proper matching shades.
Blue is one of popular color of sapphires, and even blue sapphires are considered icons of love, commitment, power, together with wisdom. Rulers across the world placed blue sapphires in incredibly high consider, as they thought the gems would protect them from hurt.
Even after choosing the perfect shade stones, Jacob black & C. needs to commit months to be able to properly established them. The result is an impressively intricate and attractive watch with a bottom dial totally covered for precious frigid blue sapphires using the challenging and superior “invisible setting” (meaning barely any of the helping metal is certainly visible). John & Co. has been within the forefront connected with using treasured stones since its founding in 1986, and has produced a number of specific cuts as well as setting strategies. For the Astronomia Tourbillon, the brand name developed the actual 288-facet Jacob-cut diamond. This specific special slice can be accomplished by only a select few gem blades, and the difficult stone generally starts out twice the size of the particular finished gem. The sides have to be amazingly precise and so the diamond is normally perfectly symmetrical and rounded. In the Astronomia Art, the main one carat Jacob-cut diamond spins on alone in half a minute. The globe is constructed of blue-lacquered magnesium with white gold continents to guarantee consistency in weight, since all four satellites have to think about exactly the same. The world rotates on itself within 30 seconds, during travel around the switch in ten full minutes. The time display screen sub-dial belonging to the Jacob as well as Co. Astronomia Tourbillon Wintry Blue Sapphires is motivated through an infinitesimal differential method that allows that to constantly remain levelled and comprensible as it rotates together with the movement’s four-armed podium across the the front of the Astronomia. The Both roman numerals around the skeletonized call are hand-engraved and loaded with black ename, while the hand-finished hands can be bought in gun yellowish metallic. Enough time display sub-dial of the Astronomia Tourbillon is driven by using a infinitesimal differential system that enables it for you to always continue to be always in the correct 12/6 angle as it moves together with the movement’s four-armed base across the entry of the Astronomia. The Roman numerals about the skeletonized face are hand-engraved and containing black lacquer, while the hand-finished hands include gun blue metallic.
زمان کنونی: 23-12-2025، 12:38 AM Persian Translation by MyBBIran.com - Ver: 6.5
