تالار گفتگوی کیش تک/ kishtech forum › پردیس فناوری کیش › زبان های خارجی › زبان انگلیسی v
« قبلی 1 … 11 12 13 14 15 … 22 بعدی »
مطلب جدید هوا و فضا
مطلب جدید هوا و فضا
Noora.ghanbari آفلاین
ارسال‌ها: 13
موضوع‌ها: 13
تاریخ عضویت: Jun 2020
07-08-2020, 11:15 AM
One of the most amazing discoveries of late, is that NASA has just declared Earth is appearing to have a second moon that has been orbiting around our big blue sphere for nearly a century now, without our knowledge whatsoever.
That’s right, a second moon! However this moon isn’t exactly the same size as the other one. In fact it should be called an asteroid that just so happens to be wandering around with us as we fly through space.
Luckily this second “moon” was found by the Pan-STARRS 1 asteroid survey telescope located in Haleakala, Hawaii.
This asteroid has been extremely illusive due to it’s sporadic and unusual path of orbit around the Earth. Tilted at eight degrees, the asteroid is considered to be highly elliptical, which makes it able to travel within the ranges of 38 to 100 times the distance, compared to our “first moon”.
This moon is also being referred to as asteroid 2016 Ho3. Apparently it has been captured in our gravitational pull for just about a century and has been doing a wonderful job of evading our eye for the stars above. In addition, the asteroid makes it’s way around the sun for 365.93 days, which is seemingly a tad longer than Earth’s 365.24.
Spanning about 40 meters across and about 100 meters wide, the asteroid’s orbit tends to be one of the more harder things to track. Because of it’s tilt as well as elliptical orbit, the asteroid may appear closer to the sun and can seem to be moving extremely fast compared to our planet. At other times the asteroid may be found farther away but moving slowly.
According to a researcher, the asteroid is expected to never get closer than about 14 million kilometers away from Earth. They also claim that the asteroid will never stray off it’s course more than 40 million kilometers.
تایید شد: ناسا یک قمر جدید برای زمین کشف کرده است.
یکی از جالب ترین اکتشافات اخیر، کشف دومین ماه برای زمین است که یک قرن است به دور کره آبی بزرگ ما می  گردد بدون اینکه درباره آن اطلاعی داشته باشیم.
قمر دوم زمین توسط تلسکوپ Pan-STARRS1 که در هاوایی قرار دارد شناسایی شده است. به دلیل مدار چرخش عجیب و غریبی که این قمر داشته تا به حال از دیده‌ها به دور مانده است. مدار این قمر بیضی شکل است که باعث می‌شود قمر جدید در فاصله‌ی بین ۳۸ تا ۱۰۰ برابر فاصله‌ی کنونی ماه از زمین، به دور کره‌ی خاکی ما بچرخد.
این قمر با نام 2016 Ho3 شناخته می‌شود و صد سال است که در میدان گرانشی زمین گرفتار شده و در این مدت توانسته از چشم‌ها به دور باشد. به علاوه این قمر در مدت ۳۶۵.۹۳ روز به دور خورشید می‌چرخد که اندکی از ۳۶۵.۲۴ روز ماه کنونی ما بیشتر است.
مدار این قمر با پهنای ۱۰۰ متری و گستره‌ی ۴۰ متر که دارد یکی از سخت‌ترین مدارها برای رهیابی است. با توجه به شکل بیضی مدار این قمر، به اشتباه اینطور به نظر می‌رسد که شی تازه کشف شده به دور خورشید چرخیده و سرعت بسیار زیادی دارد. اما در مواقعی ممکن است قمر با سرعت کم و بسیار دورتر به نظر برسد.
با توجه به تحقیقات انجام شده این قمر از فاصله‌ی ۱۴ میلیون کیلومتری به زمین نزدیک‌تر نخواهد شد. و همچنین بیش از 40 میلیون کیلومتر از زمین فاصله نخواهد گرفت.
کاربرانِ درحال بازدید از این موضوع: 3 مهمان
زمان کنونی: 06-04-2026، 01:42 AM Persian Translation by MyBBIran.com - Ver: 6.5
