Cutting Fabric with Cricut using Cricut Design space - نسخهی قابل چاپ +- تالار گفتگوی کیش تک/ kishtech forum (http://forum.kishtech.ir) +-- انجمن: پردیس فناوری کیش (http://forum.kishtech.ir/forumdisplay.php?fid=1) +--- انجمن: سامانه آموزش آنلاین رهیاران (http://forum.kishtech.ir/forumdisplay.php?fid=209) +--- موضوع: Cutting Fabric with Cricut using Cricut Design space (/showthread.php?tid=95255) |
Cutting Fabric with Cricut using Cricut Design space - hensen5005 - 22-09-2024 Each of the Cricut Maker as well as Cricut Explore Air 2 setups have great cutting capabilities. If you're a customer of one of the Cricut models, then you are able to create a craft machine by going to cricut.com/setup and start cutting fabrics with this machine. The first thing to do is set up your account at cricut.com/setup. Following that, you will need to install the Cricut Design Space at cricut.com/setup. After the setup process has been completed on cricut.com/setup, you will be able to follow the steps provided below. [list=1] [*]Before starting the process, be sure that you've got Cricut Design Space downloaded from cricut.com/setup . [*]Palace the mat with the fabric and make sure it is properly positioned on the mat. [*]Brayers can be used to smooth or flatten the fabric if it is not flat or smooth. [*]Following that, you will need to insert the mat into the machine. [*]You can make use of the water-soluble fabric pen to track the pieces you have used while making complex designs. [*]It is also possible to load the pen in the machine and write anything you want with it. [*]Check out the illustration of the design displayed in the display. [*]Put the materials in the Design Space. [*]Use cotton since it is very easy to cut. [*]Select Go. [*]Get rid of any debris that may be on the mat. [*]Make use of a pair of broad-tipped tweezers in order to take away the mat's cuts. [*]This is how you can quickly cut fabric with your Cricut machine for cutting. [*] To set up your Cricut You can go to cricut.com/setup.
