How much do movies and TV shows to cost to own on Vudu? - نسخه‌ی قابل چاپ
+- تالار گفتگوی کیش تک/ kishtech forum (http://forum.kishtech.ir)
+-- انجمن: پردیس فناوری کیش (http://forum.kishtech.ir/forumdisplay.php?fid=1)
+--- انجمن: سامانه آموزش آنلاین رهیاران (http://forum.kishtech.ir/forumdisplay.php?fid=209)
+--- موضوع: How much do movies and TV shows to cost to own on Vudu? (/showthread.php?tid=95253)
How much do movies and TV shows to cost to own on Vudu? - hensen5005 - 22-09-2024
When it comes to buying titles,  Vudu.com/start  offers the same flexibility in pricing as its rentals. Movies cost between $4.99 and $24.99, depending on video quality and if the title is a new release.
TV shows are slightly more expensive, especially episodes. Single episodes cost $1.99 to $2.99 apiece, while full seasons run $14.99 to $45.99.
How do you rent content on Vudu?
When you select a title on the service it will give you the option to rent or buy. Once you've selected the rental option you'll be asked to pick the video quality of your stream.
Vudu.com/start supports up to 4K Ultra HD video (if your internet is fast enough to handle it). Video content comes in standard definition (SD), high definition (HDX), and 4K Ultra HD (UHD).
For new releases, Ultra HD releases can sometimes cost more than standard HD. Usually the difference is not more than a few dollars, but you should take note.
After paying for a rental you have 30 days to watch it before your rental expires. Once you start watching, users have 24 hours to finish the title before it gets deleted.
How much do rentals cost on Vudu?
Movie rentals for catalog titles on  Vudu.com start code  typically cost between $0.99 and $5.99. The cost of your rental usually depends mostly on your video quality. However, you'll regularly be able to find UHD video for rent at the same cost as SD and HD titles.
Occasionally, new releases and UHD content are more expensive. This is particularly true for movies that are still in the theater. During the pandemic more titles than ever are making their debut via streaming early access.
Early access titles can cost up to $19.99 to rent, which isn't absurd when you consider the cost of a movie ticket.
