Activate Peacock on various devices: - نسخهی قابل چاپ +- تالار گفتگوی کیش تک/ kishtech forum (http://forum.kishtech.ir) +-- انجمن: پردیس فناوری کیش (http://forum.kishtech.ir/forumdisplay.php?fid=1) +--- انجمن: سامانه آموزش آنلاین رهیاران (http://forum.kishtech.ir/forumdisplay.php?fid=209) +--- موضوع: Activate Peacock on various devices: (/showthread.php?tid=81750) |
Activate Peacock on various devices: - hensen5005 - 18-03-2024 Activating NBC's Peacock TV on your Roku TV is even more comfortable if you follow these steps. [list=1] [*]First, open Roku TV's channel store, locate Peacock TV, and select "Add Channel". [*]Open the Peacock TV channel, and select the option to sign in with an activation code. [*]Go to Peacocktv.com/tv on your phone and enter the activation code or open the app, then scan the barcode using your smartphone. [/list] How To Connect, Sign-in Activate Peacock TV On Apple TV?
Before activating Peacock on your Apple TV, you need a Peacock account. If you don't have it, simply create an account by signing up with your email at Peacock's official website. Follow the steps below to connect Peacock TV to Apple Devices.
[list=1][*]First, locate the Peacock TV channel app in the Apple App Store on your Apple TV. [*]Install the app by selecting the install button. [*]Launch the Peacock tv app you just installed and sign in with your Peacock TV credentials (create one by visiting peacocktv.com). [*]If you do have an account, you may use an activation code to activate peacock tv on your Apple TV as well. [*]Go to Peacock.com/tv enter code on a web browser and enter the 6-digit activation code shown on our TV. [*]After entering the code, select continue. The peacock TV app will reload and you will be able to access it on your Apple TV once again. [/list] How To Connect, Sign-in Activate Peacock TV On Amazon Fire TV / Firestick?
These steps will guide you through the process of setting up Peacock on your Fire TV.
[list=1][*]The first step is to look for the Peacock TV channel app on your Amazon Fire TV. [*]Select the install button to install it. [*]Open the Peacock TV app you just installed and sign in with your Peacock TV credentials (create one by visiting peacocktv.com) if you don't have an account already. [*]Visit Peacocktv.com tv on a web browser and type in the 6-digit activation code shown on your TV. [*]After entering the code, select continue. The peacock TV app will reload and you will be able to use it on your Amazon Fire TV again. [/list] How To Connect, Sign-in Activate Peacock TV On LG Smart TV?
Follow these steps to easily activate Peacock on your LG Smart TV.
[list=1][*]First, open the LG Content Store and locate the peacock tv app. [*]Select the Peacock TV app and install the app on your LG Smart TV. [*]After installation, log in to the app using Peacock login credentials (if you don't have a peacock account, follow the instructions above to create an account). [*]Alternatively, you can choose to activate the account using the activation code. [*]Go to Peacock.com/tv enter code on a web browser and enter the 6-digit activation code that appears on our TV. [*]Select continue after entering the code. The peacock TV app will reload, allowing you to access it on your LG Smart TV. [/list] |
