Can the max.com/providers code be used multiple times for connection? - نسخهی قابل چاپ +- تالار گفتگوی کیش تک/ kishtech forum (http://forum.kishtech.ir) +-- انجمن: پردیس فناوری کیش (http://forum.kishtech.ir/forumdisplay.php?fid=1) +--- انجمن: سامانه آموزش آنلاین رهیاران (http://forum.kishtech.ir/forumdisplay.php?fid=209) +--- موضوع: Can the max.com/providers code be used multiple times for connection? (/showthread.php?tid=107662) |
Can the max.com/providers code be used multiple times for connection? - hensen5005 - 04-12-2024 Each code is designed for single-use to link a device with the Max service. If you wish to connect additional devices or need to reconnect an existing device, a new code must be generated through the Max app on the respective device. The Max.com/providers code is a gateway to a trove of digital content across many devices in an era of ad-free viewing. With this key, you can access the Max app to transform your entertainment experience. Through 2024 WarnerMedia Direct, LLC, this initiative aligns seamlessly with an era defined by instant internet service, including ad-lite options for HBO Max. |
